14BFF, 8-6lug adapters and Rallye Wheels - no fitty
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aandpman, Oct 11, 2003.
  1. aandpman
    aandpman 1/2 ton status Premium Member
    Sep 6, 2001
    151
    7
    Austin, Texas
    Im getting pretty close to swapping out my 10B's to 14BFF and D-44. I've searched and read some posts about using 8-6 lug adapters and 6 lug wheels.
    However, when I started doing some measuring, I found that the center hole in the spare rallye wheel measured 3.5" in diameter. Most of the posts state that the hubs on the 14BFF must be turned down to 4 5/16" to get 6 lug wheels to fit.
    /forums/images/graemlins/thinking.gifAm I missing something here? A 3.5" center hole won't fit over a 4 5/16" hub.
    I happen to like the look of the stock rallye wheels, and that's the only reason I'd even think of doing the spacers.
    What 6 lug wheels are you guys using on adapter/spacers? Definitely can't be the rallyes.
    Otherwise I guess I'll have to go the 15x8x8 route from summit or someone else.
    Any input would be cool and pics even cooler. /forums/images/graemlins/thumb.gif
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    When you convert the 14bFF to 6-lug, the stock Rally's won't fit. You need to use Toyota/Nissan/Isuzu or aftermarket wheels as they have a larger center hole.
    Maybe you can have the stock Rallies cut out to the larger size? /forums/images/graemlins/thinking.gif
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ditch the Ralleys. The stock center cap won't fit over the 14FF hub either. /forums/images/graemlins/tongue.gif
  4. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    just get them bored out to fit , i dont have rallys but my steelies didnt fit either .i havent done this ,mine axle is a 12 bolt with the WARN ff kit .
