14bff 8 lug to 6 lug
Discussion in 'The Garage' started by K30Blazer, Feb 10, 2007.
  1. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I am looking to go to a 14 bff rear and dana 44 front and would like to have the same bolt pattern. Currently have 6 lug so that is that I would like to stay with. Does anyone make a 14 bolt conversion kit from 8 to 6 lugs?
  2. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    well this question is asked like at least a few times a month. theres a company at geartechhd.com, but i havent been able to get ahold of them for a while. i am in the same boat as you and would really like 6 lug ff. kinda like a sleeper type thing.
  3. K30Blazer
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    sorry, searched and nothing came up
  4. goldwing2000
    goldwing2000 Guest
    It will be easier (and probably cheaper) to switch the front to 8-lug and get new wheels.
  5. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    im pretty sure dynatrac sells a kit to do this, but its well over 1000$
  6. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    A lot easier to put a 8 lug front on your truck and get new wheels 8 lug 15" rims on summitracing start at like 45 bucks a piece.
  7. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    IMO i would just try and find a 14b sf cuz its 6 lug like what your wanting and its plenty strong and would be cheaper than tryin to convert a ff or just get 2 8 lug wheels for the rear and run 6 lug in the front. if they are the same wheels whats the diff unless you couldnt stand haven 2 more lugs in the rear than the front. i have ran like this cuz i didnt have 8 lug hubs and no one ever made fun of me:D that i know of:haha:
  8. goldwing2000
    goldwing2000 Guest
    Not all 14bsf are 6-lug. In fact, they're somewhat rare judging from what I've been finding lately.
  9. 85mudbogger
    Feb 5, 2007
    226
    missouri
    i have 3 14bsf 6lug and 1 8 lug i know they are rare but cant you just buy 6 lug axles and drums for the 8 lug version i might have to go out and check this out and try this one, i was just sayin if he could find one it would be cheaper and without the 1 ton front what good is a 14bff in the back why not upgrade both and not just one, i havent broke nothin but my spiders in my 10b rear but now the front 4 short sides and one long and all had the ears taken right off so none were reusable. good thing i got 13 more sets for a ten bolt and when im thru with them ill go to my 5.13s and 60f:D Im just stating my opinion here i might be wrong about the 6 lug axles fitting the 8 lug sf but if they do i think it would be way cheaper to get a beefy 6 lug rear this way and not the 1000$ conversion kits. good look man:confused:
  10. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Lets clear up all misconceptions...
    To my knowledge a 14bFF can't be turned into 6lug economically.
    14bSF come in 3 different lug patterns: 8 lug (most common), 6 lug, and 5 lug (very rare). The 14bsf first came out in 81 and was unchanged until the new body style trucks in 88. And in the original 81-87 run, the 14bsf is a dirrect bolt on, but only came in 8 lug. The newer style from 88 and up was available in all 3 lug patterns. 5 lug only came on the 454SS pickup, 6 lug came of some heavy duty 1500s and some light duty 2500s depending on the trucks GVRW rating and I believe the 7200lbs rating is what you need to look for, the 8 lug version came in most of the 2500s and some 3500s. The newer style will not bolt directly in because the spring perches and shock mounts are in different locations. So you can just cut them off and weld on new ones to the correct placement.
    There is more info, but I don't have the time now to type it all up. So I say do a search on the 14bSF and 14bSF 6 lug conversions.
