14bff and 56" rear springs complete, with pics
Discussion in 'The Garage' started by 85mudblazin, Jan 30, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I finished installing my 14bff with 4.88 gears and my 56" rear springs with a shackle flip using 2wd fornt hangers. Its so awesome and I got the lift height perfect, the front is 1/4" higher than the rear :D
    Just need to get my new driveshaft shortened and hook up the shick and go for a drive :)
    Here is the link to the pics
    14bff and 56" spring install
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Looks good. What are the mounts from? Front 2WD?
    Do you plan on adding any bracing from the bottom of the frame to the back of them mount like stock? It just seems like it's a lot of force to be putting on 4 bolts.
    Not a put down just a suggestion.:D
  3. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Shibby!!!!! Was the bright red finger part of the install? I'm guessing so LOL.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Yea the mounts are off a 2wd and they are the rear spring front mount.
    Yea I am adding a brace out of 3x3 angle iron, I just finished cutting it actually :)
  5. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yup thats what happens when a 10b drope on your finger :mad:
    Hurts bad, I think the tip is broken :crazy:
  6. Esteban86K5
    3,712
    Bakersfield, CA
    Glad to hear it. Great job!!
  7. AkMudr
    Dec 30, 2004
    917
    Alaska
    Owe ****. I know how you feel. I was poppin wheel studs outta my 10B to change the rotor...yeh..I missed..
  8. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    looks good
    what are you doing for a front axle?
  9. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    im just gonna re-gear the front to 4.88 and leave it be untill I can afford a D60
  10. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    cool
    are you gona convert to 8 lug or just leave it 6?
  11. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    whos black rim? It looks good with the black rim:cool1:
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yup going to convert the front to 8 lug.
    Those are my new rims I bought from summit, they came white but I painted them black :) I like them :D
  13. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    nice:waytogo: did you use the stock shackles from rear?
  14. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Are you sure that your new hangers are from a 2 wheel drive? They look more like the tall ones used for the front mount on 4x4 trucks.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I am pretty sure they are, there are two different sizes athat are used one is the size of mine and another is alot longer that you have to trim the tops off to fit.
    And yes that is using the stock hanger, but they hit under full flex so I am going to fab up some new ones. :)
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay cool!
