14BFF and Detroit Locker assembly ??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aandpman, Jan 20, 2003.
  1. aandpman
    aandpman 1/2 ton status Premium Member
    Sep 6, 2001
    151
    7
    Austin, Texas
    Getting ready to put the Detroit Locker in my 14FF /forums/images/graemlins/thumb.gif and have a couple of ??
    I did Xploratory surgery today on the diff and found that I'll be needing to replace the carrier bearings. /forums/images/graemlins/frown.gif Anyone know offhand the PN for those?
    When reassembling the open type carrier with the DL inside, do you include the side thrust washers that came out of the open diff when it had the spider gears in it or just assemble it with no washers at all?
    Thanks everyon for a great board! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I can't help with the part numbers, but you don't want to leave any of the thrust washers in place.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Do NOT include the thrust washers that were part of the open diff. These MUSt be taken out. There should be nothing inside the carrier except the detroit locker unit itself.
    For the carrier bearings, I bought mine from Randy's R&P.
    -- Mike
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Bearing #s coming up. Just wait a couple of hours.
  5. Blazer79
    1,816
    Timken bearing 387A, Race 382A. I think they are the same as the inner bearings on a 14bff.
    I had to replace mine when I installed my detroit too. /forums/images/graemlins/frown.gif Mine wer $20 each (Timken brand) in my country.
  6. aandpman
    Sep 6, 2001
    151
    7
    Austin, Texas
    Just want to say I give Kudo's /forums/images/graemlins/thumb.gif to Randy's Ring & Pinion Randy's Ring & Pinion.
    I called them today to order bearings for the 14FF and WB's for one side of the D-44.
    The order guy (Paul ext 5567) was very knowledgeable, friendly, and their prices on /forums/images/graemlins/usaflag.gifTimken /forums/images/graemlins/usaflag.gif bearings were the best I have found (like who can even FIND timken locally anymore anyway).
    Master overhaul kit W/O shims for the 14FF was $98 - that's Pinion Bearings, Carrier bearings, gasket, Pinion Nut & locktite
    $29 for D-44 one side wheel bearings complete with seals and grease.
    $4 for the Spindle Bearing Kit
    297 u-joints (newer forged) were $21.63
    I believe I'll use these guys again.
    For all you rural folks - isn't internet mail order cool - all you need it a Credit Card and a telephone. Beats driving 50 mi to the nearest competent /forums/images/graemlins/ignore.gif Parts house....
    /forums/images/graemlins/truck.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/truck.gif
