14bff bearings
Discussion in 'The Garage' started by k5freak44, Jul 17, 2005.
  1. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    hey guys,
    if my 14bff came out of a running pickup, do you think i need to replace the bearings?
    how many of you replaced them before you did the 14bff swap?
    i havent done any kind of bearing on my k5 before, so what are good brands?
    how do i get the hub open to replace them?
    thanks alot :laugh:
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    it wouldnt hurt to look at/replace them, gm uses timken or whatever it is for bearings.
    i replaced all the bearing in my 14b before i put it in
    to take the hub off to inspect/replace the bearings just take the 8 bolts out that hold the axle shaft in, then remove the first spindle nut (you can buy a special socket or use a screw driver and hammer) remove the lock washer thing, then the other spindle nut. then you have to remove the drum/hub assembly and i think thats it
  3. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    yea i have already gotten all of that off and my rotors mounted.
    thanks i guess ill go find some bearings
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
  5. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    im looking at this seal on the back of the hub...
    how do i remove it correctly?
    i dont wana tear it up but it kinda seems frozen in the hub
  6. k5freak44
    Jun 1, 2004
    2,164
    Plano, TX
    i just read your post mechted, any way i can do this w.o a puller
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    just replace the seal. It is only like $5 at Pep-Boys
