14bff bearings
Discussion in 'The Garage' started by scrappyk5, May 16, 2006.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i am getting my 14bff ready to instal and i want to pack the hub bearings.
    i got the seal off and the large bearing out to pack , but i cannot figure out how to get the smaller bearing out. the one closest to the end.
    anyone ?
    its a 14bff from a 1978 3/4ton
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    pretty sure there is a clip inside the hub that comes out of the backside.
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    The small bearing goes in, then it's followed by a heavy duty snapring. You must undo/remove the snapring first before you can get the bearing out. I've found that a good set of needle nose plyers can be used to get the snapring out.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    you dont need to pack those bearings. Just squirt them with 90w.
  5. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    are you serious :confused:
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Very serious, these bearings receive their lube from the differential gear oil. Just drop some 90w gear oil on them so they aren't dry and you're good to go.
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Yep, 14ff bearings get an oil bath. No packing needed.
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    kinda surprised these replies didn't come sooner. you'll find out exactly how they stay lubricated when you go to fill the 14. it takes a minute.
  9. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    cool , i am glad you guys told me. :bow:
    i am getting closer and closer :D
