14bff bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 454k30, Nov 25, 2006.
  1. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    Do the bearings in the 14bff get packed with grease? Mine is apart right now and it seems as if the 90w gear lube is the only thing in there! I want to put this together right.
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    No grease, just gear oil. It won't hurt to grease the bearings with assembly lube(white lithium) to protect them against pre-mature wear during initial movement/break-in. You can also lift the passenger side of the axle a couple inches when filling to add a little extra oil.
    Jimbo
  3. 454k30
    Sep 13, 2004
    1,613
    California, MD
    hadnt thought of the tipping the vehicle thing but sounds like a good idea to get some extra oil in there.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Just don't overfill it too much.
    Oil expands when it gets hot and you need some breathing room in there.
    I usually just fill it till the oil is to the top of the hole and is flowing out and I plug it real quick, that usually is enough to keep both side lubed enough on off camber.
    :D
  5. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I packed the sh!t out of the bearings when I put mine together. Hopefully you can't have to much lube in there. :o
  6. DaPlumber
    DaPlumber 1/2 ton status
    Apr 4, 2003
    212
    Holland Oh.
    Fill it till the oil is to the top of the hole and then some more then put the plug in. Now lift one side up as much as you can for about 5 min. let the side down, now fill it up to the fill hole agine now lift the other side for 5 min. then fill agine!!! Or you may find what I did........
