14bff brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by punchdrunk, Jan 2, 2002.
  1. punchdrunk
    punchdrunk Registered Member
    Jul 7, 2001
    33
    santa cruz, ca
    can anyone tell me the socket or sockets needed to remove the rear hubs on my 14 bolt?also,whats the torque specs and is there anything special about changing these brakes?
    thanks, Doug
    Work is for people who can't fish!<font color=blue>
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Big Nuts! Ha. I think I have the socket - we will see if someone can tell us what size they are.
    If no one answers fire a PM to thatK30guy.
    Dave
    Horn Broken... Watch For Finger.
    <a target="_blank" href=http://coloradok5.com/gallery/Daves-Pics>http://coloradok5.com/gallery/Daves-Pics</a>
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    The socket I have is 2.5" - dont remember what diff it was for tho. Big fukr from one of my Motorhomes.
    Dave
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The one that I have that fits all 3 of mine is..
    KD tool #2770. I got it at NAPA for around $30.
    The brakes on a FF is the same as doing the brakes on a 1/2 ton once the hub assy is removed.
    The hole for backing the brakes off may or may not be in the backing plate.
    If it is not in the backing plate it will be on the outside of the drum. locate the indentation and using a chisle and hammer knock out the tab.
    Your best bet is to get a manual and follow the directions to adjust the bearing. The Haynes I have explains it pretty good.
    AFAIK there are two different typs of adjusting nut and lock nut set ups.
    The one on my 73 has a square key and a keeper ring.
    The one on the K5 has a lock ring that you bend a tab over to lock it all down.
    It is a pretty easy job, just do one side at a time so you have one complete side for reference.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Powermad,
    Thanks. The diff he has is a 91 - do you know what type of retainer is on that?
    That 91 14FF has all sorts of webbing on it. Looks wild and cool!
    Dave
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It depends on the year of the axle. The one for my '74 14-bolt FF takes a spanner socket, similar to the front axle, except it's slightly larger in diameter and has 6 pins instead of 4. I've got a socket that I got from Mac Tools that actually fits both. It has an inner ring with 4-pins for the front axle and an outer ring with 6 pins for the rear axle. Pretty handy tool to keep in the trail box! [​IMG]
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    WEEEELLLLL???? Didja pull the axle??
    Is your driveline being shipped yet?
    You need to get that piece rolling for Hollister on the 12th...
    Dave
  8. punchdrunk
    Jul 7, 2001
    33
    santa cruz, ca
    thanks ron,i'm going to napa tommorow.I called around and got the torque specs today, so everything looks good
    Doug
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Reading a POR post and someone mentioned that the 86 and up 14s have drums that are seperate from the hubs. They smokin crack?
    Pull the wheel and check first - I'll 'search' here and on the net for 14 bolt specs/schematics for the different years.
    Dave
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    all of them are seperate arent they?
    held by the studs
    formerly 77chev
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    OK let me make sure I'm not f'd in the head. I have the disks on mine so I am no authority fer sure. My motorhome had the 1 piece drum and hub - and it was a heavy POS!
    You need to pull the axle out to get the drum and hub assembly off, correct? Is that one pieceor 2? The post I was reading made it sound like the drum slid over the hub (and I guess the studs).
    I think you posted in that topic - the 14 FF disk brake post...?
    Dave
