14bff breakage?
Discussion in 'The Garage' started by PsychoticDeadGuy, Nov 22, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i havent really seen any broken 14bff around here, but what does it take to break one? mine is lincoln locked and the rest of it is stock. what are the actual limits of this axle? i am sure i wont ever go past those limits but what will break one?
  2. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    A heavy right foot... no gear oil... improperly set up gears. Im sure if you had lots of HP you could break them with big tires (like over 44" big). Those big military michelins could do it... heavy mo-fos.
    j
  3. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    We got a guy local that snapped a shaft on his 14 in his jeep, running 42" IROKS. A weak engine, Dana 300 tranny, you know, kinda run of the mill stuff. Super clean break, the shaft was either a bad shaft, or was just work out.
    The biggest weakness of a 14 bolt strength wise, is they are used, and how were they used before you got it? The 14 that WAS in my truck, was in a 3/4 ton that had about 60k original miles. When I put it in, I had to rebuild most of the axle. It had been abused. They used the truck like a dump truck... The one I've got in there now, sat with water in the housing. Again, had to be re-worked, but what is wrong that I CAN'T see.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    About the only beakage I've heard of is: spinning the axle tube loose from the diff. It's pretty hard to bust a 14's shaft. Not saying it can't be done, of course, just saying that it rarely happens.
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I kind of broke mine. My u-joint snapped on the yoke, when that happened it clean broke the ears of the yoke on the 14, I was on the street too. But I was being dumb and doing some burnouts with my 38's for the neighbors.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That video is amazing. If you watch the tires you can see the drivers side move about 1/2 a turn while the passenger barely moves at all.
    Ira
