14BFF Can I put 4.88 gears on a 4.10 carrier?
Discussion in 'The Garage' started by bigburban383, Jan 25, 2004.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Can I put 4.88 gears on a stock carrier with 4.10s? The axle is a 14BFF off a 3/4 86ish Suburban.
    Another thing I was quoting gear prices, the front D44 is offered in 4.89, you don't think it will be bad to run 4.88 in the rear? Its really not different and I would run it, but you wise men know more then I.
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    You can run a 4.88 on a 4.10 carrier you just have to buy the thick gear set. As far as the 4.89 or 4.88, It seems some of the manufacturers have slightly different numbers like that. Chevy is 4.10 and I think dodge/mopar is 4.11. I don't know why they are like that of if it would really matter. could be that when the gear teeth are divided one rounds up and the other down.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    5.13's. really look at it. 4.88 isn't that far away.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    5.13s /forums/images/graemlins/thumb.gif
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'm becoming one of you Zakk, going 5.13s front and back.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If I ever have money, those will be in my next stage of buildup /forums/images/graemlins/smile.gif
  7. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Isnt the pinion even smaller as in even weaker?
  8. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Try to actually FIND a set of 5.13's in stock anywhere. I'm hearing they're on national backorder and nobody has them.....
    /forums/images/graemlins/shocked.gif
  9. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Could someone make a list in this post as to what gearsets will fit certain carriers of specific axles? That would be awesome, as I too would like to know what gears (thick/thin and ratio) I can put in my 3.73 D44 and 14 bolt FF. Thanks. /forums/images/graemlins/thumb.gif
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    MWAHAHAHAHAHAHAAA!! My indocrination of the wolrd is complete! Backorder on 5.13's is MONTHS! (PLURAL!!)
    My work here is completed. I will go into hibernation and meditate on the next item i can pontificate for /forums/images/graemlins/cool.gif
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    The D44 carrier split is 3.92-up & 3.73-down, so you will need a new carrier to go up to 4.10 or numerically higher.
    The 14BFF carrier split is 4.56-up & 4.10-down. You can reuse your current carrier for OEM 4.10's, but you will need thick gears for 4.56, 4.88 & 5.13's. /forums/images/graemlins/thumb.gif
    From what I understand, the 4.56-up carrier is harder to find lower gears for. The thick gearsets are easier to come by. /forums/images/graemlins/thinking.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Although weird, this is true. I guess it's becauase of where the break is, not too many 4.56 and up vehicles were produced, so the 4.10 and down carrier is more popular and has more gearsets available.
  13. heavy4x4
    Aug 28, 2002
    3,270
    Thanks!
    So, say I wanted to put 4.88's in my, currently 3.73, D44 and 14 bolt, I'd have to buy;
    *4.88 "thick" gears for the 14 bolt
    *4.88 standard gears for a D44 (is there any distinction between front/rear?)
    *3.92-up carrier for the D44 (is there any problem putting a different carrier in an existing housing? Do you just swap over the carrier bearings and call it good?)
    Sorry 'bout the questions, but the differential is one place I haven't ventured beyond simply changing the gear oil.
  14. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Your shopping list is missing install kits. Both the front and rear will need to be set up from scratch, to get the pattern on the new gears correct.
  15. heavy4x4
    Aug 28, 2002
    3,270
    Right, I knew that...just didn't include it. /forums/images/graemlins/thumb.gif Gear change time is a long way away.
  16. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Some day I'll let you know how I like the 4.56's /forums/images/graemlins/thumb.gif
