14bff carrier and pinion swap???
Discussion in 'The Garage' started by gambit420s, Jul 30, 2005.
  1. gambit420s
    gambit420s 1/2 ton status
    May 17, 2005
    294
    KnoxVegas, Tennessee
    can i swap the carrier and pinion from a 80 14ff w/3.73 open carrier to a 73 housing that currently has 4.10 open carrier?
    i did a search and came up with a yes but i'm still not sure if i'll have to reshim the pinion for depth. this is really my question will i have to reshim??
    can anyone, who has actually done this please post up??
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    odds are you can just transfer over the pinion assembly and carrier from the axle, along with any shims it had in there....
    but the safe way to do this is actually check the pattern and reshim as necessary. you dont want to have the rear end break on you because you didnt perform something so simple
  3. gambit420s
    May 17, 2005
    294
    true true
  4. gambit420s
    May 17, 2005
    294
    anyone else?
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    I Have done it several times with no problems, just check the mesh patterns when you are done like mechted said. keep track of how many turns of the carrier shim/adjustment collars you made on the old housing and use this as a start point in the new housing
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I just swapped the shim's with the pinion and its perfect
