14bff carrier question
Discussion in 'The Garage' started by Hossbaby50, Apr 9, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ok, I want to send my spare set of spider gears, cross shaft, and side gears to KidJethro to get welded. He says I need to send the carrier too. But I can't really disassemble my rearend to send the carrier with the gears due to down time which I can't have. If I get another carrier out of a 14bff from a Junk Yard or something is this ok? Or is there certain clearences involved with my carrier and gears that would be different between carriers? I just got my 14bff together with 4.56 gears and I don't want to have to get new gears or have them resetup. Is the junk yard carrier ok or do I need to send my current carrier that is on the 4.56's with the spiders.
    Also, the spiders I have are my spares. Will this be a problem with anything gear related etc? Thanks
    Harley
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Any carrier should work, and any spiders should work too. Detroits bolt into any 14 bolt carrier, so I don't see why a set of spiders needs would need to be matched to the carrier. </font>
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Well, I think now would be a good time for ya to send me your stuff, I have a 14b torn apart in the shop right now. With carrier out as well. If ya want to send them within the next week or so, I could use my carrier to set up your stuff. All I'd need in that case is your 4 spiders, 2 side gears, cross shaft and possibly the 4 little cup shaped washer things that fit on the back side of the spiders. And thats just cause I havent split my carrier apart yet too see what shape those washers are in. They break and crack often. You are right in not wanting to send a full carrier all the way from AZ...36lbs is alot to ship that far. /forums/images/graemlins/eek.gif PM me if ya want to do this, and we'll set somethin up. /forums/images/graemlins/thumb.gif
