14BFF conversion question
Discussion in '1992-Present Chevy & GMC models' started by thezentree, Nov 18, 2003.
  1. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    what year/model 14BFFs will fit a 97 yukon? i heard that some are narrower than others.. /forums/images/graemlins/confused.gif
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    I just put a 94 14 bolt in a 99 tahoe.
    I think any 14 bolt from 92 to 2000 (same body style) will work.
    I havent compared the older 14 bolt to the newer one.
  3. thezentree
    Sep 19, 2003
    7,198
    NC
    cool, thanks /forums/images/graemlins/thumb.gif
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    With the 8-lug SRW trucks, there's only one track width. The 6-lug have a (narrow) 2wd and a (wide) 4wd.
    Plan on running mixed wheels since the 8-lug conversion up front requires the entire front suspension - if it will even bolt to the frame /forums/images/graemlins/tongue.gif
    Best "clean" upgrade is a 14-bolt Semi-float from a K1500 (w/F44 package) or 6-lug K2500. Everything is a bolt-in, except you'll need to fab brackets to keep your rear swaybar.
  5. thezentree
    Sep 19, 2003
    7,198
    NC
    SRW? (edit - single rear wheel?)
    as for the front, im going SFA /forums/images/graemlins/grin.gif got a D60 sittin in my friend's shop /forums/images/graemlins/thumb.gif
  6. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    Why not convert the 14bff to 6 lug? This is a pretty easy mod.
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] Unless your talking about just using some spacer/adapters, it is a very hard job that should be done by an axle shop.
  8. thezentree
    Sep 19, 2003
    7,198
    NC
    dana 60s are 8 lug.... /forums/images/graemlins/wink.gif
  9. blasterD
    May 24, 2003
    410
    Anchorage Alaska
  10. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    hes going SFA doesn't need that
