14bff diff cover Kit R and D parts big big discount
Discussion in 'General Parts for Sale' started by cybrfire, Jun 4, 2004.
  1. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    OK, I have 3 of these kits available they were made for R and D purposes and each of them has two holes that are off a scoshe or two. It took me just a couple of minutes with a die grinder to ream them out in the appropriate direction. Here some pics.
    This is what I'm selling
    Mine fits no prob.
    Here are the holes that need to be moved.
    A close up
    I got a little carried away with the moving of the holes. No biggy. It will not be a sealing issue or a strength issue. Just not quite perfect so you can buy them real cheap. These are laser cut 5/16" thick peices. All you got to do is slap some side peices on and weld it up.
    $20 plus shipping.
    If you want them please reply here. Please no pm's it gets hard to keep track of the order sometimes.
    Also have 3 of these for Dana 60s. same deal two holes out of whack even less though than the ones pictured. I'll get some photos of those up tomorrow.
    Hossbaby50 got one of the 14 BFF kits.
    TruckNutzdude has a 14 and 60 kit coming.
    WhiteRhyno has a 60 kit coming.
    Last 60 kit sold locally.
    14 bolt kits are gone.
    60 Kits are gone
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I'm interested. How much would shipping to 85006? If it is expensive I might only want the ring with the holes in it. Thanks
    Harley
  3. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    10 bucks shipping.
  4. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
  5. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    How much for one D60 and one 14bolt ring shipped to Feeding Hills, MA 01030? Also, do you need anything in trade /forums/images/graemlins/wink.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I will take one if you can wait till Friday for me to send the money order out. I get paided then. PM me your info if that is cool. Thanks
    Harley
  7. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Did you want the whole d60 setup or just the ring?
  8. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Harley
    No problem. My addy is on its way. PM'd.
  9. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    There's more than just a ring? Show me what you've got /forums/images/graemlins/thumb.gif and to answer your question, yes, I was just looking for the rings front and rear.
  10. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    It's the rings and top plates. Check out the first pic. You would need to add sides for an entire cover or use the ring and add a strap for a gaurd. You might as well take the whole setup though for the cost difference.
  11. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Just ran some zips through shipping and for one cover kit its about 10 bucks anywhere. For both its only 2.85 more so if you want both it doesn't cost didly squat more for shipping.
  12. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    two d60 kits left anybody need/want them? build a diff gaurd or an entire cover.
    Here's the one I put on mine. Just like the kit I'm selling except no sides. Couple holes out a whack but not by much.
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    how wide should the side pieces be to clear the ring gear? 3"-4" /forums/images/graemlins/thinking.gif
    Jeremiah
  14. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Hey
    if i can get the d 60 ring and top plate for less than $30 shipped to 98926 I want one.
    Thank you
    Brad
  15. cybrfire
    Dec 15, 2002
    15,143
    574
    Iowa
    Jeremiah
    I used 3" flat stock on both of the ones I put together. That is plenty on the 60 cover and probably a 3/16" clearance on the rear one. I'm putting it together so you fill the entire corner with weld.
    Like this _| so the whole bar stock is above the ring and below the top.
