14bFF disc conversion - wheel stud fitment - is this normal?
Discussion in 'The Garage' started by Shaggy, Dec 24, 2002.
  1. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> OK, the axle is from an 87 SRW 1 ton. I asked for rotors for a '78 3/4 ton. The recesses on the back of the rotor were not large enough for the heads to drop all the way into, so I had to turn about .2" off of all of the studs. Is this normal, is it just because the axle was from a 1 ton, or was I supposed to buy new studs? It works fine so I'm not going to replace them, I'm just curious about it since I hadn't heard anything about this issue in any of the hundreds of disc conversion threads. Pics -
    </font color>
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    When I did my 3/4 ton 14ff, the studs were to short. had to use front studs.they are longer. the heads were ok though.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bought some rotors from autozone for a 78 3/4 ton as well. They had holes in the back of them that were big enough...but the rotors that were on the front end (which I ended up using in the rear so I could have the new rotors in the front) didn't have a big enough hole. I just bolted it together and called it good. I like you solution better.
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The rotors that I bought had the holes big enough. I wonder if its just an aftermarket brand thing.
  5. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    no issues with mine
  6. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I had the same problems...the 3/4 rotors I bought from Napa had a recess that was 1" in dia. and the wheel studs had a head dia of 1.12" /forums/images/graemlins/eek.gif So I turned down the head .12"...also the studs I bought were too long so I trimmed .25" of the OAL....perfect fit now... /forums/images/graemlins/thumb.gif
  7. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    I had no issues with mine. I used my old front rotors from a 77 D44. The wheel studs from my one ton 14 bolt fit fine and weren't too long either.
    The only minor snag i ran into was a small cast tab on the caliper needed to be ground off to let it bolt up to the bracket. 2 minutes with the grinder...
    Rene
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I did mine several years ago, using the TSM brackets that required rotors from the front of an F-250. The recesses in the back of the Ford rotors are too small for the GM studs, so TSM offered rotors with the holes machines out larger, but they were expensive! So I bought the rotors locally from Autozone for $34 each and used a bench grinder to remove a small amount of material from the heads of the studs, just like you're describing. /forums/images/graemlins/cool.gif This way I can use an off-the-shelf rotor if I ever manage to damage one. Those studs are massive, so I seriously doubt that this would cause much of a problem with strength. /forums/images/graemlins/thumb.gif
  9. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I did the same, but mine was cause I have that 8 lug to 6 lug ring I made to keep my 6 lug rims. You can tell people even the wheel studs are custom...
  10. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Shaggy,
    That happens sometimes.... Scott (4x4HIGH) told me the same exact story as you when he did his rear disc brake conversion...all the bolts had to be turned down or they wouldn't seat right (dangerous!)
    I pulled my entire rear wheel assemblies apart (for about the 3rd time) expecting that we were going to have to do the machining on my bolts as well. For some strange reason, mine were fine and didn't need machining....my only guess is there are slight variations in the suppliers of rear disc rotors (which are actually 3/4-Ton fronts right?) and sometimes there is an extra edge there that interferes....
    Weird, but true. Just another one of those THINGS that people don't realize about the "so called" simple 14BFF swaps....! /forums/images/graemlins/eek.gif
  11. bigbluek20
    bigbluek20 1/2 ton status
    Dec 18, 2001
    119
    Loveland, Colorado
    What year did GM switch to the 14FF that had drums independent of the hub/bearing assembly?
    My axle is from a 78 (I think) and it went together fine with the D44/10Bolt Rotors
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Thanks for the replies, guys. Sounds like this is just one of those "sometimes" things that sometimes needs to be dealt with during the disc swap. Hopefully this thread will help someone else be prepared later on. /forums/images/graemlins/thumb.gif </font color>
  13. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I happened to read this yesterday. I go to press the studs in the hubs and check the heads first . /forums/images/graemlins/shocked.gif /forums/images/graemlins/mad.gif
    I did the same ordered 78 3/4 ton front rotors this is going on my "3/4 ton" 14 bolt.
    Rotors Part #105014
    New wheel Studs 9/16-18 x 3" Part # 610-189
    I used a t snap gauge and calipers.
    Rotor hole- 1.033"
    Wheel stud head- 1.121"
    The Wheel studs we are grinding have a 1 1/8" head I turned all 16 on a lathe down to 1.000" head diam and pressed em in.
    I wonder if the problem is the other guys have wheel studs with 1" heads or is it the manufacturers variations of rotors with a countersink hole larger than 1"? /forums/images/graemlins/ignore.gif /forums/images/graemlins/rolleyes.gif
  14. TONYP
    Aug 13, 2002
    2,116
    so cal
    I turned mine down to 1.00" to fit my spacer ring..
