14bff disk conversion questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Seventy4Blazer, Feb 19, 2002.
  1. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what all do i need other than brackets for a 14bolt disk conversion? will D44 calipers work?
    and what else? where do i bolt the rotor up? in the back just like the drum? any write ups on this subject?
    is 20 dollars a caliper a good price?
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  2. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    If you go to my for sale ad " i also have 14 bolt disk brake brackets" on page 3 or so and find the post by prediator he did a great write up on his install. It includes everything you need and a price list. Check it out.
    <P ID="edit"><FONT class="small">Edited by DERBINATOR on 02/19/02 05:55 AM.</FONT></P>
  3. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The rotor goes behind the hub just like the drum does, and the studs are pressed in from behind. You can use D44 calipers, and $20 each sounds about right
  4. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    misfits backing plates are for sale again in the for sale section, and he does great work.
    <font color=blue> Jeff - may the force be with you</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/Jeffs-Stuff>link to k5's</a>
