14bff DRUM identification?
Discussion in 'The Garage' started by MattK, Nov 6, 2005.
  1. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    hey guys, im plannin on puttin new shoes in my 14bff pretty soon and im wondering if anyone can point me in the right direction as far as ID'n my 14b brakes.
    i know there are a few different sizes and id imagine they have a diff shoe for each size right?
    thanks in advance for any help.
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It is pretty obvious on the difference. There is a 13X2.5 and a 13X3.5. The 3.5" wide drums are F&^%ING huge. If you already have the old set of shoes just measure the width. If it came from a 3/4 ton it is most likely 2.5" wide and if from 1 ton most likely 3.5" wide.
    Ira
  3. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    thanks for the help. if there are only those 2 sizes im certain i got the 3.5. i saw my axle sit next to another 14bff and my brakes were definitely bigger.
    thanks again dude
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    There is also a 14ff with 11" brakes and one with 13" brakes but from the sounds of it you have the 13" brakes now it's just a matter of the width.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    :hi jacked: do the disc swap :hi jack off: ;)
  6. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    i completely agree. just dont have the cash for that yet. itll happen as soon as i find some caddy calipers.
  7. UseYourBlinker
    Jun 7, 2000
    11,117
    When said and done..
    DIY bracket's $67
    Rotor's $100
    Calipers $60
    4x4High lunch priceless....LOL
    It was about $300 total.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    :haha: :haha: :haha:
  9. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    where'd you find those calipers for 60 bucks?
    and how would you suggest getting them? junkyard and swap as cores?
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Eric doesn't have caddy calipers. Your best bet though is the wrecking yards and buy a set of caddy calipers and if they don't leak run them or use them as cores since the caddy calipers aren't cheap either is the core charge, the last i remember the core was more than the caliper.
  11. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i had a factory 3/4 ton with 13" dia 3.5 wide shoe setup. :D
  12. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Hey Matt. If I recall correctly, the 3.5"x13" drums cam off of CUCV's only. I'm sure somebody will tell ya if that's wrong. I have the 3.5" wide brakes and they are too strong for my blazer- panic brake and the back locks right up. I need to run a proportioning valve in line to fix it.
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    My 14ff came from a 1986 2wd burb with 454/TH400 and it had 13" x 3.5" brakes.
  14. sandawgk5
    Oct 28, 2003
    6,881
    I guess I kinda miss spoke. The size of the brakes is determined by the brake code i.e jb5,6,7 or 8 JB6 is disc front and 13X2.5 rear with vacuum booster, JB7 is disc front with 13X3.5 rear with vacuum booster and JB8 is dana 60 disc front with 13X3.5 rear with Hydroboost. I was not aware of the JB7 option on 3/4 ton but I recall out 1980 CC camper special had 13X3.5 rear drum.
    Ira
  15. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    well i guess ill just get off my ass this week and measure them myself lol.
