14BFF drum removal
Discussion in 'The Garage' started by Mastiff, Dec 27, 2005.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I need to get the drum off my CUCV (1986) 14BFF axle. I have the shop manual, but it's not clear exactly what I have to do just to get the drum off. It has a section on pretty much tearing everything down to the bearings. Can someone explain what needs to be done just to get the drum off to access the brake parts?
    I see that I need to pull the axle out, but then? Do I need to remove the outer bearings, or can I just remove the "adjusting nut" and pull it off in one big piece?
    TIA
  2. trikstark5
    trikstark5 1/2 ton status
    Feb 17, 2004
    169
    usa
    Remove your axle on the drum you are trying to remove. Inside the hub, there is a locking nut you need to remove. You will need a special socket, 6 tabs, to remove the nut. Afterwards, take the washer out and then there is a another nut you must remove. Once that nut is removed, just pull the drum off. You may need to you a dead blow or hammer to free it up, but it should come off without too much of a problem. Good luck!!!
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Cool, thanks.
  4. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Is lube from the diff going to try and pour out when I remove the axle? Should I jack it up at an angle or something?
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    some will leak out... or small stream.. not like it is going to gush ya...
    I use a box and put a trash bag in it to catch it...
    good luck man...
    p.s. the special socket for the 14bolt is the same as the one for the front d60 :wink1:
  6. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I went looking for special socket and neither of the shops I went to knew what I needed. I'll need to take it partially apart to see what it looks like. Is there pretty much only one kind with 6 tabs? I found one at O'Reilly with 6 tabs, but it said it was for one ton 4x4 front hubs or something.
  7. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    thats the one, read up a post or two, he said it is the same one for a D60 front(1 ton 4x4)
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks. I just pulled the axle out, so now it's pretty obvious what I need. By the way, how do you get the key out? Just try and get vice grips on it and pull? I tried some needle nose pliers, and it seems pretty tight.
  9. dave_90_blazer
    Jan 1, 2004
    688
    did you remove the snapring?
    if yes, i use a magnet, and wiggle the nut till the key comes out
    if that is the one i am thinking of.........................
  10. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Yeah, snapring is out. I just tried to yank the key out. Sounds like maybe the nut is pressing againt the key. I'll get the tool and work the nut a little and see if the key loosens up. Thanks again.
  11. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Well, this turned out to be a pretty easy job. :thumb:
    The only problem was that the last guy must have gone at everything with an air wrench or something. One of the axle nuts was stripped (I had to re-tap the hole), and half the lugs nuts are also stripped. I had my 850 ft-lb impact wrench on full and it took a while to loosen them. :mad1:
    A question: Are the bearings greased, or kept alive by gear oil from the diff? It looks like diff oil gets to them, but I also saw some grease in various places. If they are greased, these ones really need repacking since I could see right through them.
  12. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    lubed by the diff fluid
  13. trikstark5
    Feb 17, 2004
    169
    usa
    The bearings are lubed by the gear oil, just make sure you aren't low on the oil after you reassemble everything.
  14. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Well, I was just about to wrap up this project of replacing the parking brake cables, and I noticed one of my wheel cylinders wasn't right. One of the little connector rod things that connects to the sides of the wheel cylinders is gone. I found it on the ground later, all kind of mangled up.
    Do you guys think I can find a replacement for that and just put it in, or do I have to buy an entire wheel cyliner setup? There's no brake fluid leaking or anything, and it looks like it's been working, since the shoe that still has the connector is more worn down.
    I realize this is just general maintenance stuff, but I've never torn apart a drum brake setup before. TIA
  15. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    It would probalbly just be best to buy a new cylinder. I think they are $20 at the local auto shops. That way you get new seals on both ends and wont have to worry about matching the new pushrod to the old seal. I've seen it where just replacing the pushrod ends up with a leaky seal and uneven braking in the rear, which can be pretty scary.
    Al
