14bff for sale (wash)
Discussion in 'Engine | Tranny | T-case' started by red77blazer, Feb 14, 2005.
  1. red77blazer
    red77blazer Registered Member
    Feb 13, 2005
    47
    Washington
    14 bolt and other parts off a 72 motor home, any other parts needed ask.
  2. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    CC or SRW? You might want to add the spring perch dimensions and shock location since motor homes are a little odd. Brake size? Price? Gears? Locker or open?
    Good Luck,
    Eric M.
  3. red77blazer
    Feb 13, 2005
    47
    Washington
    thanks-
    havent gotten it out yet, i will ad those measurements when it comes out, more than likely though it will need perches rewelded, i'd re weld it but more than likely wil a k5 with lift the person buying will want to make his/her own calculations for pinion angle(i assume). I havent even got the whhel covers off the tires as i'm just focusing on the engine and trans right now. But if your seriously interested reply and i'll get what i can quickly.
  4. eclipse
    eclipse 1/2 ton status
    Jan 1, 2005
    1,245
    Sparks, NV
    Single or dually rearend? And how much?
    I'm in Spokane Washington.
  5. red77blazer
    Feb 13, 2005
    47
    Washington
    its a dually right now but if you need measurements i'll have it out tomorrow-i'm in sequim-near port angeles
  6. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Well, I might even be able to help arrange delivery... I have to go up to Vancouver Island this weekend and could come back thru Port Angles to pick it up. Then drop it off when I get over to Spokane in a couple weeks.
    That axle is probably going to be a different width than a SRW truck axle (if it is 2-3" wider it would be a bonus though). I think a 1 ton C/C is 63" (too narrow for a pickup/k5/sub), SRW is 66 or 67" and the Van width comes in closer to 69 or 70"?
    Spring perches will most likely be 40" apart like on the 1 ton trucks though. Shock mounts are not a big deal to reweld either way.
