14bff gov loc????? is it a bombshell
Discussion in 'The Garage' started by buhlandy, Apr 28, 2007.
  1. buhlandy
    buhlandy Registered Member
    Dec 2, 2006
    44
    tn
    hey guys ...i know for a fact that the 10b gov locs are freakin bombshells.... lol but upgraded to a 14ff rear and was wanting to see if the gov locs from a 14ff are worth a crap???? are they bombshells liek the 10b or will they hold up ... i have a stock tbi 350 and a 241 tcase and 38x12.5 tsl ... if that helps any ... it has 3.73 gears for now ... but i want to upgrade... would a gov loc work for my app and hold up ???? and are the gov locs like a fact. locker or more of an lsd????? any help you guys have will greatly help me .... i always get great help here in the garage..
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The 14ff are better than the 10/12bolts, but not sure I would want one for a wheeler. I had one in my 97, but that was a driver not a wheeler. They lock when you don't want them to, won't lock when you need it to lock, etc. They are unpredictable IMO. But with a 350 and skinny tires, I would think that it would hold up. When they do decide to lock, the tires are locked, so in a sense it acts like a locker...
  3. sweetk30
    Nov 1, 2004
    25,529
    527
    horseheads , ny 14845
    i had and still have it. started life in a 1ton rear with 4.10 gears. built to the hill 400 sbc. th350 with 205 tcase. 38x12.5x16.5 tsl on it. i use to mud and do lots of wheel spin. held up good for what it is and if you know how to use them. then i sold/parted out the truck. i pulled the gov lock and its now in my dd crew cab. still never got stuck with the 2wd crewcab in 2 feet of feild blown snow and new a/s tires.
    the trick is know how to use it and fell the unit lock in then hammer down .
    best tool i have had for not eating tires on street but give me traction when i need it.
    i have a brand new unit going in my next build . 88 crew cab 4x4 with 5.13 swaped in and around 10" lift and 40" tires.
  4. buhlandy
    Dec 2, 2006
    44
    tn
    so wat you are saying sweetk30 is as long as im easy and wait on it to lock and then give it hell it will be fine ... but how can i actually tell when it locks ... is it hard to tell ???
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I have one in mine, and i believe it is dead, but it didn't explode like the 10 bolts do,,,personally, i believe the 14b burns out the clutches before anything else, because as with mine, it mostly slips.
    It does engage some, but not like it probably should
    *This is an opinion and aself thought idea, no absolute fact (for those that get anal about some information passed on)
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    14bFF bombs aren't catastrophic like a 10b. Basically stop working (i.e. open diff) or the guts get mashed internally and it free-wheels.
  7. mendo
    mendo Registered Member
    Oct 22, 2006
    37
    Santa Barbara, CA
    Myne blew up about a month ago and I replaced it witha detroit. Luckily none of the metal fragments damaged my pinion or gears. Id say dont wait till it explodes and leaves you stranded and causes possible damage. It did work ok for a while, but it would never lock when I needed it to. When it did lock it was 100 percent locked though. To get myne to lock I would put it in 2wd hold the brakes and give it gas till one tires slowly spun then the other would lock (somtimes). Watch out if you have a heavy foot they will die.
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    When i had my suburban, I swapped in 1974 3/4ton axles and it still had the stock gov-loc and it still worked perfectly.
  9. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    I've flogged on mine for a good while now. It hasn't failed, but it's not fun to have to induce spinning to get em to lock up.
