14bff gurus help please (UPDATE) I CRUSHED IT
Discussion in 'The Garage' started by MTBLAZER89, Jul 6, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok let me ask this first about the crush sleeve... tightening the pinion nut pushes the outer bearing on to the pinion shaft against the crush sleeve....right?? I am doing this right now and there is about an 1/8th inch of slop still in the pinion. I figure about 2 more turns of the nut till the bearings both hit the races.
    OK I am doing this at home and I need a preferred method to do this. The axle and pinion are bolted in to the truck. I got a big piece of pipe and all that. Tonight I tried putting the breaker on and resting it on the spring then backing up...I got about a turn on the nut then this happened...... continued below..
    Is this a safe way to get a little slop out before I start doing it by hand. I would do it all by hand but I only get about a 16th of a turn on the nut with the truck sitting on the ground. Let me know if I should continue doing this or not /forums/images/graemlins/confused.gif Going to get a new breaker tomorrow /forums/images/graemlins/eek.gif
    Sorry so long any advice would be greatly appreciated. Thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: 14bff gurus help please
    Well put it this way, I broke 2 3/4" drive breaker bars and one 7" vice and one work bench crushing my crush sleeve /forums/images/graemlins/eek.gif. I used to have pics but they disapeared. I had the pinion housing clamped in vice which was bolted to the work bench. I put the breaker bar on the nut and a 6 foot 1.5" .120" wall DOM tube over that. Started yanking and once the slack was out and the sleeve was starting to crush I was hanging with my 179 pounds on the end of that 6 foot pipe and did one hard bounce and kaboom! the butcherblock workbench top split down the middle then the vice broke into several pieces and the pinion went flying to the floor along with me... Also broke the breaker bar and bent the handle. It was quite the site /forums/images/graemlins/smile.gif
    Anyway, from then on I just bolted the pinion housing into the diff housing and built an angle iron brace that slipped over the yoke and extended out and braced it against the floor of the garage. After that it was pretty easy /forums/images/graemlins/wink.gif
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah I already broke a vise thats why I waited till everything was in the truck. I am still wondering if driving to crush it is a good idea or should I get something to hold the yoke and do it by hand??
  4. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I'm confused, you say you were doing it with a big breaker bar and pipe, but want to know if you should be doing it by hand... That is by hand man! I needed a good 6 feet of leverage on that thing to get it to crush... Sounds like what your doing is right, just keep going and check the preload constantly. Once the bearings were seated and they started touching the sleeve on both sides I was checking preload about every 1/8 of a turn...
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah I am using a bar on the end of the breaker resting it on the leaf spring then backing up....pinion turns nut is held in place ..tightening up.
    I am in chat if anybody wants to discuss this there. /forums/images/graemlins/thumb.gif
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    TTT for MT!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    anybody that can help please meet me in chat about 6:30-6:45 please I am not making much progress here /forums/images/graemlins/confused.gif
  8. crazykev4x4
    crazykev4x4 1/2 ton status
    Jun 30, 2003
    430
    Watertown,Wisconsin
    i always put the crush sleeve in the press first just till it starts to crush and then it goes easy from there they r a sob to crush . i have stripped the threads off of a new pinion trying to crush one
    Kevin /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep, crush it using a press. Thats how I do all of them, its a little easier then by hand and all, lot less broken tools too!
  10. AnthonyG
    AnthonyG 1/2 ton status
    Jan 26, 2003
    339
    Gillette Wyoming
    I maxed out a 600 ft pound torkwrench on mine and still didn't crush
    I founsd out that the pinnion nut was grinding against the yoke insted of pushing it down
    the press is the way to go
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It's all done wasn't as hard as I thought..set to 30 inlbs then put the new seal in and locktite on the nut /forums/images/graemlins/thumb.gif tomorrow comes the rest of the setup hopefully. Thanks everybody. /forums/images/graemlins/thumb.gif
  12. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I use my 1/2 Impact wrench to crush the crush sleaves. Yes it does take a few minutes but its a hell of a lot easier than using a breaker bar.
