14BFF help...
Discussion in 'The Garage' started by SCJimmy, May 6, 2004.
  1. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Weird shake on my K5 from 58+ mph. Put the rear 14BFF up on jack stands, and it looks like the center of the drive flange and hub are not turning true. Is it possible to have a set of out of true or bent hubs? /forums/images/graemlins/confused.gif
    New bearings/races when I rebuilt the axle before the swap. I checked the spindle nut, both sides are torqued tight, so what gives?
    It's a 1980 CUCV axle.
    If I need new hubs, where's the best place (outside of the stealership) to order a pair?
    Byron
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Are you sure it's the hub? Could it just be the drum that's making it look like the hub is out-of-round?
  3. SCJimmy
    Mar 7, 2003
    406
    I'm prety sure it's the hub. I sighted the outer edge of the hub at the flange against a stationary object. You can see 1/8" or so as the hub/wheel turns. Guess I need to locate some new hubs, or???
  4. SCJimmy
    Mar 7, 2003
    406
    I'm pretty sure it's the hub. I sighted the outer edge of the hub at the flange against a stationary object. You can see 1/8" or so as the hub/wheel turns. Guess I need to locate some new hubs, or???
  5. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Pull the hubs off and check to see if the races are in all the way and straight. Maybe give em a tap to make sure and then re check to see if they spin true.
