14bff help!
Discussion in 'The Garage' started by raptorparts, Aug 31, 2004.
  1. raptorparts
    raptorparts Registered Member
    Aug 31, 2004
    16
    gastonia, nc
    have a 78 half ton i swapped a 75 14bff into a few years ago using the stock 78 half ton springs..swap went without a hitch after i had the driveshaft madeup for it...wore the 75 rearend out, located a 79 rearend, installed it and it sits 1 inch further back on the springs than the 75 14bff did!!!...i've swapped a bunch of this stuff around and never seen or heard of any perch differences on the 14bff for the years 73-87...i've rechecked to make sure i'm on the dowel pins like i need to be and i am but the wheels are clearly pushed back to the back of the wheel well....WTF!!!
  2. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    If you truly are on the centering pins then I'd be at a loss. Try looking at the leaf springs. Leaf spring eyes, bushings that sort of thing. The center pin hole in the perch wallowed out to far? Just some suggestions.
  3. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Drive shaft still hook up the way it did before? Just as a way of checking that has indeed moved back and not an optic illusion.
  4. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    Maybe you got one of those rare '79 one inch offset spindle 14BFF that I have only heard tell about. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    It isn't Rocket Science; check to see where the center pin hole is located compared to your old axle.
  5. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Did you change the springs too??.I saw a truck come in my friends shop that someone put new leaf springs in,but they didnt realize the center bolt isnt exactly in the center of the spring,they put the springs in backwards and the rear wheels were back too far in the wheelwells--the driveshaft fell out when he drove it onto the alignment rack lift!. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif If thats not the case,I dont know what happenned,something must have moved,or maybe the axle is a one year wonder or something--or bent? /forums/images/graemlins/ignore.gif.
  6. 85HeartBurb
    85HeartBurb 1/2 ton status
    Jan 10, 2002
    735
    Temecula, south
    Do the perches look stock? maybe the previous owner put aftermarket on to move it back instead of using zero rates?!?
