14bff help!!
Discussion in 'The Garage' started by berg76, Aug 1, 2003.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    its been awhile since ive taken my 14bff hub races and bearings out. Now I cant remember which direction the outer bearing is installed /forums/images/graemlins/confused.gif. I dont have a reference book to look at. only ck5.com /forums/images/graemlins/smile.gif.
    so does the outer bearing slope the same direction as the inner? or does it go the opposite where they form a 'V' if you look at the spindle from the side. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif
  2. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Yes, they both point toward each other...something like this > <. Make sense?
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    kind of off topic- but-
    I think we need either a 14FF or just axles forums. SO many questions deal directly with dana 60s, numbers, and 14ff's it's absurd. just look at the number of axle posts.
    or maybe a lower drivetrain forum- yeah, i just made that 'lower' drivetrain thing up if it isn't real, i just mean t-case-driveshafts-axles etc. i think this might make searches and proble solving easier. just a thought.
  4. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    anyone else?
  5. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I agree with that. I've done a lot of searching since I purchased my K20. I looked up hub rebuilds and front u-joint replacing, and a couple of others. Having it all in the same forum would make future searching way easier.
  6. berg76
    Nov 4, 2002
    238
    St. Louis, Missouri
    Thanks for the help. One step closer to 3/4ton!!! /forums/images/graemlins/thumb.gif
