14BFF Hub Leaking
Discussion in 'The Garage' started by BigBadCad, Sep 24, 2003.
  1. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    Me drivers side hub on my 14BFF is leaking gear oil from the inner seal. The seal is fairly new since I replaced it during the rear disc conversion. I was wondering if I missed anything during the assembely process or is the spindle shot? What are my "cheapest" options if the spindle is scored or grooved?
    thanks in advance,
    aj
    BTW-I can't be certain but I believe the hub was leaking oil before I tore it apart for the disc swap.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    When you rebuilt it, did you put in new bearing race's in the hub's? If so, doe's the outer race butt up against the internal snap ring?
    If it is'nt butted up, there will be play in the bearing's, and allow, oil to leak past the seal/spindle area. /forums/images/graemlins/grin.gif
  3. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Mine leaked because I overfilled my diff by half a gallon.
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    did you put some gear lube on the seal before you installed it on the spindle? if you didnt, it would cause the seal to wear fast.
    or did the seal happen to get installed backwards?
  5. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Hey I have the same problem! I may have over filled but seems to be a steady leek, I also just replaced the bearings and races, hmm what did I do wrong? /forums/images/graemlins/thinking.gif
  6. woody9
    woody9 1/2 ton status
    May 27, 2001
    602
    Howell, MI
    Me too! Twice!
    When i first put the 14FF under my sub, did all new drum brakes/hardware and double checking everything. A number of months later, when i was starting the conversion to disc, pulled apart the pass side, and the brakes were all wet! Seal was leaking, but hadn't yet become viewable! (those $50 shoes were soaking it all in!!! /forums/images/graemlins/shocked.gif ).
    Now, after about a year with disc on there, i just noticed it's starting to get wet near the inner seal!!!
    I wonder if there was a bad batch or two of seals out there, or ??? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    Understand the CW seals are supposedly better than most. Also (worst case?) there's a sleeve (super-thin thing) that can be installed over the existing axle stub to give a new surface for the seal/bearing...??
    hmmmmmmmmmmmmmmmm??
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Re: Me too! Twice!
    Speedy Sleeve is what you're thinking of...
  8. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Me too! Twice!
    hmm..we had that problem with chevy4wds, on the 3rd or 4th seal it finally stopped leaking..
