14BFF LockRight Installation
Discussion in 'The Garage' started by rcamacho, Jan 23, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Anyone have a tech write up on this? Specifically I'm looking for some guidance on validating the side gear clearances since the carrier is mostly blind.
  2. goldwing2000
    goldwing2000 Guest
    Did you already buy the lockrite? For almost the same money, you can get a Detroit and the installation is the same, if not easier.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    The instructions were pretty good. I found a write up searching the web...
    I did this in a couple hours, taking my time, cleaning everything, having a couple beers, sending pics to friends with the camera phone.
    EDIT: OK heres one http://www.off-road.com/chevy/tech/detroit/ its for a detroit locker but its very similar.
    http://www.pirate4x4.com/forum/showthread.php?t=328610 also for the Detroit. Mine hadnt been touched since it was all put together over 30 years ago. The gear oil was kinda nasty but I just cleaned it all and put it back together and everything works fine!!
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    Yep. Picked one up for ~200 shipped which is a heck of a lot lower than I could find a Detroit.
  5. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    from were?
  6. rcamacho
    Jul 1, 2004
    1,324
    WA
    Ebay! :)
  7. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    ok, I'll keep my eyes out....
  8. goldwing2000
    goldwing2000 Guest
    It's a decent deal but you can get Detroits all day long for $370 (less on eBay) and have a much stronger unit.
    Anyway, best of luck. It should come with instructions but if it doesn't, you could probably download a pdf from the manufacturer web site.
  9. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    I think beast383 or something like that did a good write up about 3 months ago
    Ahh crap I'm blue again...
  10. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Not trying to be a dick, but how are the 14BFF Detroits stronger than Lockrights? Just curious.
  11. goldwing2000
    goldwing2000 Guest
    They're just stronger by design. A Lockright is like "Locker Lite" for people who want a drop-in unit without the hassle of a full install. Except that when you're dealing with a 14bff, the full Detroit is an easier install.
  12. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Detroit and Lockright are both lunchboxes for the 14 bolt ff, hence my question.
    I understand if the full case detroit was the case it would be stronger, but it isn't the case (that was a horrible pun, I am sorry).
  13. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I did a small pictorial about the Detroit install.:D
  14. goldwing2000
    goldwing2000 Guest
    All lunchboxes are not created equal... ;)
  15. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    ok, so whats different?
  16. goldwing2000
    goldwing2000 Guest
    Call this number:
    (800) 328-3850
    Ask them what the difference is. If they tell you that they're both the same, I'll withdraw my opinion.
  17. rcamacho
    Jul 1, 2004
    1,324
    WA
    The lock right re-uses the cross pin and side gears. Additionally the couplers on the lockright have a comparatively small tooth profile. So, the lockright is more likely to strip the couplers or break the stock side gear.
    Is that worth ~$200 price difference for me? -In this case yes. If I were a hard core offroader than maybe not.
  18. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    thanks!
  19. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Thats correct. The detroit is an overall stronger unit. In fact, its arguably the strongest locker you can buy. I currently have a detroit in my 14ff. I dd the truck for 2 years, and the detroit was flawless. It locked quickly, and always worked perfectly. I have a 10 bolt up font, so I wont be putting the extra money into it for a detroit. I have a lock right waiting to go into it. If I ever upgrade to a D60 however, I will definitely go with a detroit. Peace of mind.
    -Harrison
  20. rcamacho
    Jul 1, 2004
    1,324
    WA
    I just finished the installation last evening. The only real challenge was getting the ring gear bolts out of the carrier. My impact gun was useless so I had to get the breaker bar out.
