14BFF Main Caps Tq. Spec?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KRAZIE87K5, Mar 2, 2002.
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    I need to know what the torque spec is for the carrier bearing caps on my 14BFF... Anyone? I just need a quick answer. [​IMG]
    Thanks all!
    <font color=red>GOT MUD???</font color=red>
    <a target="_blank" href=http://home.attbi.com/~netwrite>Midwest Caravan</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s - 36" TSLs
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Dan, 135 ft. lbs. is the torque spec. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    Phew! Thanks Wes... just got back from Napa where I had new carrier bearings pressed on - cost =$81. Now I can go out and sit in the 5" snow, and the rain that is falling right now to re-attempt the install. Any quick pointers?
    1. Install the pinion
    2. Install the carrier
    3. Set backlash, checking for pinion depth at the same time.
    4. I'm still missing something...
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    And of course checking the pattern too...
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Hope you saved the shim for the pinion carrier support housing. You need to reuse that.
    If you have never messed with this shim and carrier support, other than take it out and reinstall it, you will be just fine with the same stock shim. That shim is what sets the pinion depth. If all is ok so far, don't worry anymore about the pinion depth as the shim already set it. [​IMG]
    I need to know if you replaced the bearings in the pinion carrier support besides the ring gear carrier? If you did, let me know. I want to know if you did the installation and checking for the pre-load properly.
    Install the ring gear and carrier. Torque to the 135 ft. lbs. spec. Don't worry about the adjusting sleeve lock wires yet. Set the back lash on that between .005" to .008". Minimum .003" and maximum .012".
    Once that is set, check the pattern.
