14bff oil leak question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by milspecjimmy, Aug 24, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i have a 14bff on my jimmy. it has an atron disc brake conversion on it, and i run 32" tires. ever since i have had it the thing has had leaky rear axle seals. the guy i bought it from replaced them both, and i replaced them both. the passenger side leaked instantly, and the drivers side took a while but is leaking again. i used a speedi sleve on hte passenger side but it still leaks. any ideas?
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    what kind of seals did you use?
  3. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    CR's chicago rawhide.
  4. Confedneck
    Nov 1, 2002
    5,236
    we've used WORLD seals without incident..and timkens i believe...both good stuff..if you find out it's the seal thats the problem, check those out..autozone..
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Did you grease up the seal real good before putting it in? If you don't grease them they will burn up instantly and start leaking again. </font>
  6. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    yeah i sure did. i cant figure this one out. i was thinking maybe it was from the extra heat from the discs but it doenst get hot enough to melt the rubber
  7. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    Is your vent clear? Maybe the pressure is making it leak cause it can't vent. /forums/images/graemlins/thinking.gif
  8. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    actually i havent checked that yet, and that may be it seeing as it doesnt leak when sitting. only when driving
  9. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I've been battling rear axle seal leaks on my 14BFF for a while now. (Since 2001 to be exact! Old Seal Post)
    First I did the speedi sleeve install. This slowed it down a bit, but still had leaks. I then used Napa's $8 seal /forums/images/graemlins/eek.gif and greased then up per advice from the guys here on CK5. The leak on my passenger's side stopped, but the drivers side kept leaking.
    Then, I swapped hubs from side-to-side and replaced the seals again. The leak moved from the driver's side to the passenger's side. This leads me to believe my hub is out of round, so I'll be replacing the hub soon to test my theory.
    Good luck with yours, I know how frustrating it can be!!
    Thomas.
