14bff pinion angle
Discussion in 'The Garage' started by SkulzNBonz, Mar 27, 2006.
  1. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The search feature is seriously lacking. I am in the middle of installing my 14 bolt, and I would like to know the pinion angle I should shoot for. I know it's supposed to be within a couple degrees of the t-case output, or just to the opposite direction. I am running a standard driveshaft, and probably will for a while. Could someone give me a clear answer befroe I tack weld my spring perches in place? Thanks, and sorry for the question that has been answered more than once here.
    John
  2. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Measure the angle at the transfercase output shaft. You want to match it (but opposite) minus a degree or two for axle wrap under torque.
  3. goldwing2000
    goldwing2000 Guest
    For a street-driven truck, that is the best advice.
    For a trail rig, point the pig directly at the t-case and glue it!
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The onlt time you point the pinion at the T-case is when you're running a CV driveshaft. Anything other than a CV shaft the driveline needs to have the same working angles front and back otherwise you will get a vibration and pre-mature U-joint failures.
  5. goldwing2000
    goldwing2000 Guest
    That's why I said for trail rig only. High-speed vibration doesn't matter at low trail speeds.
  6. SkulzNBonz
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    That's funny Daniel, I just thought aboot calling and asking you, for "some" reason I knew you would know:D Thanks for the quick answer, y'all. My rig sees the pavement, and I drive my rig to the trail, so it needs to be right for both the trail and the street.
    John
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Who said anything about high speed vibration? You will usually get a vibration at low speeds and get worse with the faster you go.
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya the pavement of your driveway
    you need some help dude? dont be afraid to call
