14bff pinion bearing snap ring??
Discussion in 'The Garage' started by 85mudblazin, Nov 11, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I am in the process of building up my 14bff, tonight I tried taking out the pinion bearing but there is a snap ring type thing that holds the bearing in there, except the snapring doesnt have anyhting to grab with the pliers, it is just a circle with a little gap in the middle.
    so I just smashed the bearing so I could get some pliers on the snap ring, I got it out but then I was thinking, Does the master install kits come with this?? If not where can I get a new one??
    -Chris
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    im lookin at a Master install kit for a 14bff right now and i see nothing that looks like a snap ring
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    which bearing are you talking about? I don't remember any snap rings on the pinion. There is a big one inside the bearing hub, but that is the only one I can think of.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    You mean the bearing in the housing? For the pinion snout?
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea sorry I mean the pinion support bearing inside the housing.
    sounds like I screwed up /forums/images/graemlins/doah.gif
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Not sure what year 14bff you're working on but my 85 14bff doesn't have any snap ring like you are describing anywhere. The only snap ring in my 14bff is in the hub that holds the outer bearing race in place and then further out that holds the adjustment for the wheel bearings. /forums/images/graemlins/confused.gif
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Just hit it out from the front with a long punch and hammer.
