14bff pinion housing
Discussion in 'Parts & Trucks Wanted' started by chrisb420, Jun 4, 2006.
  1. chrisb420
    chrisb420 1/2 ton status
    Aug 6, 2004
    652
    Binghamton, NY
    as the post states i am looking for a pinion housing for a 14 bolt ff rear it needs to have the # 3977354 stamped into it. i bought the rear for my truck at a junkyard and the guy told me it was from an 84 3/4 ton it had a wiped out pinion housing bearing, i bought a replacement from another member awhile back and it looked right but after i got the rear apart it was a different housing it had a different # stamped on it but if anyone has this housing please pm me
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The housing you bought should work it just uses a larger pinion bearing. That housing would be for 1986 and later IIRC.
  3. chrisb420
    Aug 6, 2004
    652
    Binghamton, NY
    thats good to know i bought an install kit with my new gears and it had the old style bearing that is why i was looking for the housing. but i will check price on bearing or see if i can find the different housing at the junkyard.
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The later housing used a larger bearing, just return the install kit and get the later install kit, everything else is the same.
