14bff pinion seal change..
Discussion in 'The Garage' started by XHitman396, Mar 20, 2007.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    so im gonna change the pinion seal in the 14bff and was wondering if there are any tricks or basically anything different than the way you do a 10 bolt? ill basically be going about it the same way i did the 10b, which is from a Haynes manual. i recall someone mentioning something about a 'crush sleeve' replacement and the pinion nut, too. thanks for the help..
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I am not sure if you need to replace the crush sleeve for just a seal replacement. It is a PITA to crush though. Start it in a press.
  3. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    Once you get the pinion out, the seal is a piece of cake.
    It is recommended to do a new crush sleeve, but not absolutely required Either way it will take some doing. Search on this, as I went through this recently.
    -- A
