14BFF pre-bent brake lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Jun 28, 2003.
    Where can I find the pre-bent brake lines for a 14BFF, stainless steel preferably. The axle is from a 77K20 and the brakes are 77 El Doardo calipers with SS brake hoses if it matters.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    No one makes them. Buy a flaring tool and some straight brake line and bend them yourselves. It's not hard to do and the brake line is cheap. Buy extar so you can play around with the bender and get them just the way you want them.
    -- Mike
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Standard brake line is cheap and easy to bend. NAPA can even order brake lines in various lengths that already has the spiral wrap and ends installed. (The spiral wrap is made from spring steel and helps keep sticks and rocks from hammering the brake line flat when they hit it.) /forums/images/graemlins/cool.gif
    Just an FYI, stainless steel is hard stuff and it can be very difficult to get the flares to seal properly with SS hard lines. You have to tighten the bejeezus out of 'em to get 'em to stop leaking at the fittings. /forums/images/graemlins/frown.gif
  3. thefarside
    thefarside 1/2 ton status
    Jun 27, 2003
    343
    Vernon, CT
    He's right, I tried it myself. What a pain in the ass and the results where far from perfict! Not something I would like to try do myself again. Try it if you like on a small piece of stainless. This way you are not locking yourself into making them your self, just in case you hate making them like I did.
