14BFF question (pics)
Discussion in 'The Garage' started by MTBLAZER89, Apr 8, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok I noticed these six bolts were missing today. What do they do? Can you pull the pinion out this way or something. Any help would be great. Does anybody have a 14bff breakdown manual or know where I can get one? Thanks
    -Brian
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, those hold the pinion gear in place. I'd sure wonder why they're missing though... /forums/images/graemlins/frown.gif Any decent GM truck manual should cover the 14-bolt FF. It's been around for 30 years. /forums/images/graemlins/cool.gif
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    So I can pull out the pinion with those removed?
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep. It should slide right out the front of the housing. /forums/images/graemlins/cool.gif It's been many years since I had mine apart, so I can't recall if the ring gear has to be out of the way first or not. /forums/images/graemlins/confused.gif But I'm sure someone will pop in with the answer soon. /forums/images/graemlins/thumb.gif
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I already removed the ring gear and the carrier. If I remove the pinion that way will I have to get a new crush sleeve and reset pinion depth. I know I have to reset the carrier bearing preload and all that, but I really don't want to mess with the pinion. I would like to pull it out that way to clean everything easier.
    -Brian
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    No you wont need a new crush sleeve. Its the whole assembly, bearings and all kinda like a 3rd member but just for the pinion. You wont have ot reset the pinion depth because that shim between the housing and the pinion carrier its what adjusts the pinion depth, just re use it.
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    You just leave the yoke bolted to the pinion and nothing changes. /forums/images/graemlins/cool.gif
  8. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    There are some good pics in an article here. /forums/images/graemlins/thumb.gif
