14bff question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by crazy427, Jun 17, 2004.
  1. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    Do the rear wheel bearings need to be packed with grease or are they feed gearoil from the differential. I believe they use the gear oil but i want to make sure. thanks /forums/images/graemlins/waytogo.gif /forums/images/graemlins/usaflag.gif
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    They are supposed to be packed with grease so that they dont start up dry. The gear oil will eventually get there but the bearings will be dead by that time if you dont pack them with grease. My dad did that when I was a kid, sucks replacing everything twice.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Yup, what he said.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    The other way to go would be to change the bearings then fill the diff up all the way; then before you drive the truck jack up one side of the axle real far so oil drains into the low side hub, then jack up the other side to fill the other hub.
  5. one ton burb
    one ton burb 1/2 ton status
    Nov 15, 2003
    119
    Ontario, Canada
    [/ QUOTE ]this method works great, I have done it a few times.
  6. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    I like the second one . sounds much easier /forums/images/graemlins/waytogo.gif /forums/images/graemlins/usaflag.gifThanks for the help guys /forums/images/graemlins/bow.gif
