14bff Question????
Discussion in 'The Garage' started by Supreme70, May 17, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    When you install the disc brake conversion on the 14 will I have to get longer Lug Nuts for the wheels since the studs aren't going thru the drum????
  2. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    no because thay now go threw the rotor the same as the drum would have.:D
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The lug nuts should be fine, but if you have the small 11" brakes you will need longer wheel studs to go through the rotor and hub. If you have the large 13" brakes then you will be fine. I have noticed though that the rotors aren't all made the same nor are the wheel studs so you might have to machine the head of the wheel studs to fit in the recess of the rotor.
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Mine were fine when i did the swap. My 14FF came from a M1008
