14bff,,question?
Discussion in 'The Garage' started by 4xcrazy, Mar 7, 2004.
  1. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    So, i take it the pinion needs to be pressed out of it's little carrier unit? or is there a "not so professional" way of removing this little 8a5tard?
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Remove the pinoin housing.
    Remove the pinion nut.
    Disassemble.
    Redneck way..
    Drop shaft.
    using a 3' pipe wrench and cheater bar secure the yoke.
    Loosen the pinion nut to where it turns easy.
    remove the housing and do what ya have to do.
  3. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Well i got the pinion nut off,also got the yoke off, but now it's fighting me with removal of the pinion out of the bearing housing unit. What if any,,,am i missing here? /forums/images/graemlins/dunno.gif
  4. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Did you remove the pinion housing from the carrier?
  5. 4xcrazy
    Oct 31, 2003
    9,471
    5
    yes, i am just needing to remove the pinion from the small "pinion carrier" that unbolts from the front of the axle housing. it has two bearings on it and this is why i am assuming that it needs to be pressed off?
  6. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Re: 14bff,,question? help/info please
    Well, i just went out and tried one of those 3-jaw pullers, pull the bearing carrier/push the pinion out, /forums/images/graemlins/thinking.gif didn't work, /forums/images/graemlins/angryfire.gif broke the puller, /forums/images/graemlins/doah.gif hurt my wrist when slamed to the ground. /forums/images/graemlins/tongue.gif oh well, i guess it's goin to the machine shop either tomorrow or Monday. /forums/images/graemlins/frown.gif
  7. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Re: 14bff,,question? help/info please No ones taken a 14bff apart on here?
    /forums/images/graemlins/confused.gif
    /forums/images/graemlins/confused.gifNo one can help with delima?? /forums/images/graemlins/confused.gif
    /forums/images/graemlins/dunno.gifAm i describing things correctly?? /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/frown.gifMissed my wheeling trip today because i can't get this thing apart. /forums/images/graemlins/frown.gif
    /forums/images/graemlins/ears.gifany info would be greatky appreciated /forums/images/graemlins/ears.gif
    Thanks peoples.
  8. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I just used a press to get it our of the pinion housing and to get off the pinion bearing. /forums/images/graemlins/thumb.gif If you don't have access to a press then run through a machine shop they should do it for a small $ hope I helped /forums/images/graemlins/thumb.gif
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    didn't work, broke the puller, hurt my wrist when slamed to the ground.
    Sounds normal to me......at least with our luck bro. Whenever you want come over I have a cold Smirnoff for ya. /forums/images/graemlins/waytogo.gif
    BTW hurry up and get that done , waiting on your call so I can tell ya all the wheelin' details. /forums/images/graemlins/thumb.gif
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    if you look at very end of the pinion stem notice theres a center deperession for a punch, clamp the pinion gear bearing housing in a vise or somethign and punch out the pinion with a good round punch and BFH, have someone catch the pinioin gear though
  11. thatK30guy
    Jan 12, 2001
    32,076
    55
    A press is the best, easiest, and fastest way to get them out. Every 14FF I've torn apart, I used a press to remove the pinions.
    BTW, the "little carrier unit" technical name is "pinion support housing." /forums/images/graemlins/waytogo.gif
  12. 4xcrazy
    Oct 31, 2003
    9,471
    5
    Yeah i had to miss the wheelin trip with all the buds out at FR42 here in Phoenix area, but i did manage to get the pinion off, while they were wheelin /forums/images/graemlins/frown.gif
    i ended up taking it down the street to a Firestone shop where they happened to have a press, and let me tell you, it even gave the press a workout and when it finally popped,,, it literally popped and scared all of us when it did. Man that thing was on there. But as mentioned, it was replaced so i am currently now runnin 4.10's and all 8 lug /forums/images/graemlins/woot.gif
    Thanks for the replies, it just took more than manual force to remove it.
    See ya on the trails soon locals /forums/images/graemlins/waytogo.gif
  13. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    What size was the press? I am going to install 5.13's in mine soon.
  14. 4xcrazy
    Oct 31, 2003
    9,471
    5
    I don't really know what size it was, it's at a Firestone tire and service store, so whetever they use to press things on with. It really wasn't very big, heck the pinion teeth wouldn't fit through the bottom of the press, person had to stack plates to get the gear up high enough for it to drop to release the bearing. Just a small hand pump operated press, nothing automatic.
