14bff questions
Discussion in 'The Garage' started by TxK5Blazer, Dec 3, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    sorry if these are repeats but I have a few questions.
    I just pulled and brought home a 14bff out of a 85 3/4 burb
    1. will this swap into my 82 K5 if so what mods will need to be made.
    2. hell guys I can't remember the second question. Oh well.....Jason
  2. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    spring perches and shock mounts may need to be relocated, you may or may not need a trick u-joint, other than that you oughta be set... assuming the gears match your front axle.
    j
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I don't think the gears match so will have to set up new gears in them but got the axle for a steal. I thought of my second question....
    what is the difference between the axle I got and say one out of a 1 ton truck....Jason
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    AFAIK, there is no difference... they might use different size pinion yokes or something... not sure.
    j
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Was it the stock axle from the '85 sub -- if so, it will bolt right up (except the u-joint), but I thought they were all semi floaters during that era?
  6. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
  7. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    as far as I know it was the stock axle from that burb, I could be wrong though. I looked stock the way it was in the truck I know cause I pulled it out... It was a 2wd burb if that helps or does that even make a difference....Jason
  8. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    2wd and 4wd are somewhat the same. the only difference will be the lower shock mounts on the 2wd.
    your 14ff should bolt right in without having to relocate the perches. i hope that you grabed the spring plates from the burb if not you will need those too.
    oh and new u-bolts..
  9. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    3/4 ton 14bff is a direct bolt in, its the one tons that need the spring perches moved..
  10. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Ric what would be the best plan to do with the shock mounts can I buy some from echobit and weld them on and cut the other ones off....Jason
  11. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    so basically was the burb 2wd or 4wd? if it was 2wd yeah some echobit shock mount, cut the olds off, weld the news on. If it was 4x4 slap that axle under your K5 its a direct bolt in(except the u joint issue).
  12. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    it was a 2wd burb....Jason
  13. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
  14. thatK30guy
    Jan 12, 2001
    32,076
    55
    I find it hard to believe this rear is a FF coming out of an '85 truck since the majority of these years used SF rather than FF's.
    Stupid question, but are you sure its a FF? Does it have a large hub protruding past the lug nuts? Is there a 6 bolt removable pinion support housing? Just curious as a FF in a mid-80's is almost impossible, if not very rare. /forums/images/graemlins/thinking.gif
  15. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    I am very sure that is is a full floater. It has the protruding hubs and the bolts holding the pinion support. It looks just like the one in my buddys 1 ton navy truck only thing is this one has smaller disk breaks....Jason
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    Thats pretty rare to see a FF in any mid-80's truck under a K30 rating. Lucky to get that in there. /forums/images/graemlins/thumb.gif
  17. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    disk brakes? which axle yours or his?
  18. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    sorry guys I was not thinking it has drums both axles have them ....Jason
  19. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    just to clear up some things I shot some pics of it on the trailer before it goes off to the shop to be gone through [​IMG]
  20. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Yep,Thats a full floater....
