14bFF: sealing axleshafts
Discussion in 'The Garage' started by txbartman, Jan 16, 2003.
  1. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I am finishing up my 14bFF. What do you guys use to seal the shafts to the hub? When I pulled mine, they had some thick white sealant looking stuff. I would use RTV, but while the axleshaft surface is pretty smooth, the hub surface is pretty roughed up. I question if regular RTV will form a thick enough seal.
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    There is a specific gasket for it but I use RTV. I sandblasted the hubs clean and smooth then painted them before I overhauled the axle.
  3. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    There is a thin metal gasket that goes between the flange and the hub, so i use that metal gasket and black RTV. No leaks, the sealant does a pretty good job of getting into the little cracks and sealing out the gear lube.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's another vote for RTV. /forums/images/graemlins/cool.gif Permatex Form-A-Gasket will also seal it up. /forums/images/graemlins/cool.gif
  5. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I think permatex was what was on it. It reminded me of the permatex sealeant I put on my head bolts.
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Permatex makes some awesome stuff. I keep a tube of their #2 sealer and a small tub of their Aviation sealer in the garage at all times. /forums/images/graemlins/thumb.gif
  7. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i use black rtv to seal anything that will have oil contact.its what is recommended for oil oin the tube.
