14BFF Small Parts
Discussion in 'The Garage' started by rcamacho, Mar 14, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm in need of an extra axle flange bolt and the aluminum gasket between the hub and flange. Any suggestions?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    the axle flange bolts are regilar 1/2" grade 8's, id go to the junkyard for the gasket thing or just slap some RTV in there and call it good.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks.
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    You can also get the flange gaskets new at your local parts whore (or try www.partsamerica.com) they are really cheap.
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
    Finally got around to fixing the leaking flange. The po used RTV which would not hold. The local GM dealer had a replacement gasket for ~$4. Unfortunately it's a weird paper compound rather than aluminum so it's probably a single use item.
  6. Wes Harden
    Wes Harden Registered Member
    May 28, 2005
    29
    Southern Califorina
    I got metal ones at my local parts house. Only use rtv on the trail.
    Wes
  7. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    I got the metal one at Auto Zone for $1.99 each. The paper ones will leak.
