14BFF Spindle Hardware Help
Discussion in 'The Garage' started by wforicv, Jul 19, 2005.
  1. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    Where do I find spindle hardware for my 14BFF. I am in need of the spindle flat washer, spindle nut (also called the inner spindle collar), spindle lock washer, and the spindle lock nut (also called the outer spindle collar). I have been all over Bill Vista's 14B bible, GM parts direct, etc. with no luck. Are these parts only availiable from GM? How about Randy's Ring and Pinion or West Coast Diff? Anybody have these numbers or know how the heck I can get them? :confused:
  2. avgas
    avgas 1/2 ton status
    Jun 5, 2003
    179
    Renton, WA
    rockauto.com probably has it if you know the year it came out of
  3. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I bought mine from Napa, just ask for a spindle nut kit. I think it was around $15 for each side.
  4. dyeager535
    26,979
    Since there are two designs of the 14FF, not sure if this link will help you or not, but if you want to try and get real GM parts, hopefully it will. :)
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I used the nuts and locking collar from a front Dana 60 so I only have to have one socket for my truck. The tab for the locking washer is a little wide so I just filed it down about 1/8 of an inch and it fit perfect. I got both sides on e-bay for about $20 to my door.
  6. wforicv
    Feb 16, 2004
    165
    Thanks guys, I knew y'all would come through for me :bow:
