14bff spindles
Discussion in 'The Garage' started by sandy78, Jan 21, 2004.
  1. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    I just picked up a junkyard 14bff for an axle swap, and have a spindle question. When I pulled the hub/drum assemblies, I found some scuffing and a wear ridge on the bottom of one where the outer bearing rides. Everything else looks great. Question is what to do?
    1. Ignore it and run?
    2. Replace bearing?
    3. Sleeve spindle?
    4. Trade for another axle?
    Truck will probably see approx. 2000 mi/yr. I don't need perfect, but I don't want problems on the trail! Thanks for any advice.
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    scuffing, hmm, if you can feel them with fingers then id run, bearings might be messed too, axle might have been run low on fluid for a long time, you should be able to find good ones, i had some if i had known anyone would ever need any then id have removed them before scrapping the housing,
    good luck
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    you make it sound like you can change them... but there welded on /forums/images/graemlins/thinking.gif
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    You can change them, assuming you have a jig and a competent weldor.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ill be taking mine off, if you need a new one let me know.
  6. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    well.. I know you can basically do ANY thing you want... and change a spindle if you want to bad enough, but I just though it would be ALOT easier and less head acke to pick up another housing... unless you have a SUPER nice housing with mods
