14bff spool????
Discussion in 'The Garage' started by bigbadchev84, Sep 22, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    spoo for the 14bff? where is the best place to find one?
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    dont know if its the best place to get a spool, may be the only place right now --- sandy cone of cone engineering.
    is 46 spline though. (stock is 30). custom axle shafts are a must, which sandy can supply.
    i dont think i want to know how much that would cost.
    ryan,
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Randy's Ring and Pinion carries one. Search on Pirate, plenty of places sell one that uses the stock 30 spline shafts.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    oh yeah...nevermind...i got my head up my you know what.....
    ryan
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    At your local welding shop.... :whistle:
  6. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I think Reider Racing sells a mini spool for the 14ff...
  7. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Put a spool from Randy's in my 14 bolt about a month ago. Haven't got a chance to wheel it yet. Pretty heavy duty. Do a search on here, I put up a couple pics.
  8. Habez
    Habez Registered Member
    Mar 27, 2003
    45
    Houghton/Frankenmuth, MI
    probably the cheapest "spool" you will be able to find is knows as a Lincoln Locker. They can be found all over. (weld it)
  9. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  10. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I remember that. It was a Yukon spool, right? It looked plenty beefy too.
  11. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    iirc, ouverson engineering makes a mini-spool for the 14b also.
  12. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    would a mini spool be hard to install compared to a detroit?
  13. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    For a 14 bolt it'd be exactly the same procedure except you don't have to take the wingnut on the detroit out at the end.
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    I think Sandy Cone offers two types of spools for the 14FF. One is a mini spool that works with a stock 14FF(30 spline). And then he lists one on his site that is 46 spline. Not sure if that one is a full or mini.......
    There's a guy on ebay that sells the Yukon full spools. I think they are aroudn $220-$240 now.
  15. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    what is the best way to go about welding it and not worring about breaking it?
  16. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Basically, make a solid metal ball out of the spider gears. Essentially the same thing as a mini spool except home made. I wouldn't recommend doing it like they do in the tech article here because a couple people have broken them that way.
  17. Emmettology 101
    May 9, 2000
    8,126
    FL
    Search for "spiderball"
  18. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    txfireman- Yes, it was a Yukon spool. Not too worried about breaking it. :D
  19. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Yeah, by the looks of it you could run over a land mine, blow you rig to smithereens ... and all that would be left would be that spool. :wink1: :D
