14bff swap details
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Great78burb, Oct 28, 2002.
  1. Great78burb
    Great78burb Registered Member
    Sep 24, 2002
    28
    San Diego, CA
    I have already searched, but haven't found any specific answers to my questions. I am prepping to swap a 14bff into my 1/2ton '78 Sub and was wondering what year and vehicle makes the best donor? I have been told that any 3/4 ton vehicle '73-81 will work. Are the spring perches the same from a truck to a sub? What about a van? Also will my rear lift blocks be useable, or will they not work with the 14bolt spring plate and u-bolts? I know this has probably been covered several times, I'm just having a problem finding anything specific enough. Thanks for any help! /forums/images/graemlins/burb.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    you want a 3/4 ton 14ff they bolt right up. the spring perches match. and yes you can use your blocks. the only thing you should need id new u-bolts.
  3. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Will the drive shaft have to have any work? What about brakes? Will the spring plates have to be changed to fit the new, larger U-bolts? Inquiring minds want to know. Thanks for the help. /forums/images/graemlins/smile.gif
  4. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    all stuff i was just going to ask right there..also..can you use a lift that was ment for a 1/2 ton or does it have to be heavier springs or something?
  5. beater74
    May 29, 2001
    1,749
    atlanta
    yer drive shaft will work just fine, but you will have to use one of those bastard u-joints in the drive shaft inorder to match the yoke on the 14ff. and yes any lift for a half ton will work. /forums/images/graemlins/thumb.gif
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You will need larger u-bolts and make sure ya get the spring plates from a 14 bolt. 12b/10b ones won't work. I bought a u-bolt kit for a 3/4 ton with a 4" block lift from Superlift, I can't remember the part #, but it was almost $50. The Napa part # for the u-joint you need is either #348 if your truck had a 12 bolt or #447 if it had a 10 bolt. I had a 12b so I needed the 348.....cost me $27. The brake lines hook right up....No probs there. My e-barke cables were a bit too short, so I didn't hook them up. No big deal....I could probably get them hooked up if I adjustied it all the way out...I don't miss them. make sure ya get some brake fluid for bleedin the brakes. Have some WD40 on hand for the old u-bolts. I can't think of anything else.....Good luck dude. /forums/images/graemlins/smile.gif See if you can beat my swap time of 2 hours 15 minutes. /forums/images/graemlins/thumb.gif
  7. sdavid
    Aug 5, 2002
    244
    Livingston, TX
    That's the little things I was looking for. Thanks.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I guess you had your answers, except, the Van axle will not bolt right up it's wider and the spring perches are further out.
