14bff swap have a few questions
Discussion in 'The Garage' started by TxK5Blazer, Nov 12, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I just found a 14bff for my K5 yeah I know I just swapped the rear axle under it about a month ago but I could not pass up this deal. It has 4.56 gears already so I can live with that. I am wondering if I will have to shorten my driveshaft when I install the 14bff because of the size
    of it.....Just asking Jason
    I swapped in a newer 10bolt about a month ago with 4.56 gears and just want something that won't break as often
    I hope ....Jason
  2. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I think you can move the axle back about 1" and it will be good...
  3. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    thanks tony and I can do that with a set or zero rates right ....Jason
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    are you running a stock drive shaft? If so then it should help compinsate for the lift.
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    yes i am running my stock driveshaft right now and have my transfer case droped one inch also if that is the case you are right. Now why didn't I think of that....Jason
  6. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You'll be fine with the d-shaft you have now.
    Lot's of people claim that the 14 bolt and 10 bolt have very similar measurements when it comes to the distance the yoke is from the axis through the axle tubes. Some say it's more. But, I can tell you from my experience, you'd actually need slightly more driveshaft length when making the swap. The increased tube diameter over the 10 bolt and the size of the spring perches must account for a little lift because after installing my 14 bolt FF in place of my 10 bolt, I can see that the slip yoke of the driveshaft sticks another 3/4" out of the t-case.
  7. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    [/ QUOTE ]Yep, my shaft length was better with the old 10bolt. Many people get confused, with a 10 bolt to 14 you need an extra 1" or so on the shaft. When going from a 12 bolt to a 14 then you might need a little less shaft, a 12B has a shorter pinion than a 10B.
