14bff swap question
Discussion in 'The Garage' started by ktedesco, Apr 21, 2004.
  1. ktedesco
    ktedesco 1/2 ton status
    Mar 21, 2004
    365
    Colorado Springs, CO
    I just got my 14ff the other day. I was looking at Steve's article on the homepage regarding his axle swap. He mentioned the need to change the brake backing plate. I am not sure why this is necessary. Am I missing something. I thought the swap was pretty much bolt on with the conversion u-joint. Do I need to switch the brake backing plate even if I can find the correct brake line fittings for the existing one?
  2. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    I'm pretty sure that is only if you want to run the parking brake without modifying anything. I just installed mine and I wonder if a parking brake on the driveshaft is easier to deal with? Also, I was told that you need to run a different master cylinder because the brakes are bigger, hence it takes too much brake pedal travel from the half ton master, but I'm not sure on that either.
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    IIRC. the lines are the same fittings, all you should need is bigger I.D. u-bolts, a set of 14BFF spring plates, and a cross-over u-joint, autozone part # 3-3140 Oreilly's part #348 /forums/images/graemlins/thumb.gif. I did not change my backing plates, I am running the big drums with 15" wheels and no clearance problems. /forums/images/graemlins/peace.gif
  4. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    You can run a stock MC, most of us have changed over to get better stopping power for larger tires and rock crawling, got to have good brake for that /forums/images/graemlins/thumb.gif
    I am running the stock 14BFF e-brake cables hooked to my stock K5 cables with no problem
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You change out the backing plates to a later model year so you can use the "press-in" style e-brake cables that your truck uses. You can modify the old style to work with your cables...it's hard to explain, but there was a post on it the other day...I did it to mine, it basically involves cutting a slit in one of the bracket pieces to stick the cable through.
    And no, you don't need a 3/4 ton master cylinder.
  6. heavy4x4
    Aug 28, 2002
    3,270
    Your stock cables work because you have a '79. If I recall correctly, that year still had the two cables going down either frame rail. The "newer" trucks have one cable that runs down the driver's side framerail and then splits into two just in front of the rear axle...that's when you'll run into "problems."
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    The 14B out of 1 tons's have the e-brake cables that will attach to the newer K5's.
  8. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I see, I guess I could have looked at his profile /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif, I also just remembered, my 14Bff is from a K30 /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif, has had the perches and shocks moved /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif
    Thank you for the correction /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif /forums/images/graemlins/bow.gif
  9. ktedesco
    Mar 21, 2004
    365
    The 14bff is from a 78 3/4 ton. I don't know why I didn't say that in my original post. It probably makes a differance. So the main issue with swapping the brake backing plate is for the emergency brake. I am going to look at the e-brake connection on my K5 to see how it compares to the one on the 14ff that is going in. Thanks everyone.
