14bff swap question?
Discussion in 'The Garage' started by muddawg, Sep 17, 2005.
  1. muddawg
    muddawg Registered Member
    Oct 24, 2004
    39
    Susanville, CA.
    Will the driveline length need to be changed when swapping in a 14bolt from a 12bolt?
  2. W200
    W200 Newbie
    Sep 17, 2005
    3
    San Jose CA
    14blt is about 3 inchs longer than 10blt so maybe...
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I didn't need to change anything except the ujoint at the pinion end of the driveshaft when I installed my 14bff. The stock driveline worked fine.
    Harley
  4. muddawg
    Oct 24, 2004
    39
    Susanville, CA.
    The reason I ask is because i am going to get a cv shaft made that is going to be hooked up to the 12bolt for now, but when i put the 14bolt in i want to make sure that i can use the same driveline.
  5. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    i just swapped out my 10 bolt for a 14 and it was the exact same length.
    no driveline issues atall, besides the conversion ujoint
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    X2. My buddy just swapped his 10 bolt out for a 14 bolt in his 84 K5. All he needed was the conversion joint. It's the same for 12 bolts too.
  7. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Same with mine. Just put the larger ujoint in and it worked fine.
  8. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    same here. but i did eventually move the axle back 1.5" with the ORD zero rates so i orderend a driveshaft that was 2" longer and its all good. if your going to keep the same suspension and not move the axle then you will be just dandy...
