14bff swap
Discussion in 'The Garage' started by AKbigsub, Aug 14, 2006.
  1. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    Does anyone know if I will need to lengthen my rear drive shaft when I install the 14BFF? It is a 90 3/4 ton burb with a semi floater and 4 inch lift. I have already confirmed that the u-joint is the same but am concerned about the d-shaft length.
  2. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I asked this same question for my 89 3/4 ton burb and the answer was, no.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I swapped from a 14bSF to a 14bFF in my C20 Burb - no driveshaft mods. I think the slip-joint on the driveshaft extended about 3/8".
