14BFF U-bolts????
Discussion in 'The Garage' started by Beast388, Oct 5, 2003.
  1. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I searched all over town yesterday for U-bolts to do my 14BFF swap. No one carried 3-3/8" ID u-bolts, but some had 3.5" ID's.
    So what is the consensus?....Do 3.5" ID u-bolts work or is 3-3/8" the only way to go? I measured the hole measurements on the spring plates, and the 3-3/8" look like they will fit much better than the 3.5"'s. /forums/images/graemlins/thinking.gif
    I would like to run the correct 3-3/8" ID u-bolts if possible, does anyone know of a good place from which to order them? /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    spring shops will make you any ubolt for any axle in any length...
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Yup around here thers a sping shop that does them pretty cheap with nuts and washers and there grade 8 /forums/images/graemlins/thumb.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Call Rough Country's 1-800 order line.
    I called a week or two ago and ordered a set of front u-bolts for my truck. $20 later and shipped to my door in 3 days, I had a set of u-bolts /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif
    I know they have the u-bolts for the 14 bolt because I have them, but I'm not sure if those will cost $20 too. /forums/images/graemlins/smirk.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My spring shop makes them for $5 each.
  6. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I called Rough Country....they only list a 3-1/2" u-bolt, rather than 3-3/8". Kit price was $25 + $7 for shipping. How do your u-bolts fit?
    My local (50 miles away) spring shop will make them for $10 each.
    Hmmm.....decisions decisions. /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thinking.gif
  7. heavy4x4
    Aug 28, 2002
    3,270
    Here's the story behind it. I ordered my lift system from them. Because I needed 56" rear springs for my burb, they basically ordered up a lift system for a 3/4 ton pickup. Well, they sent the u-bolts for a 14 bolt FF (because it was for a 3/4 ton pickup) but of course I had a 10 bolt. They shipped me the correct u-bolts next-day when I told them about it. But anyway, I've had the 14FF u-bolts in my garage ever since, and I just used them about a month ago when swapping in the rear axle. They fit perfectly.
