14bff ujoint question of a different kind
Discussion in 'The Garage' started by mechted, Jul 8, 2004.
  1. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    planning to do a 14bff conversion on a 1/2 ton longbed pickup... got to thinking: the drive shaft is 2 piece.. so would it be possible to remove the last section with the 1310 yoke and slide in a replacement with a 1350 yoke so you dont have to buy a conversion u joint?
    are the # of splines different on the slip portion? or the diameter? havent actually looked at the two side by side yet, any help is much appreciated
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Why dont you just use the conversion u-joint??
  3. mechted
    Oct 19, 2003
    765
    Granbury, TX
    mainly to avoid the "broke and no one has the part" thing... although i know that all Napas and Chucks/Kragen/Schucks will have them
    im really just wondering... i doubt i would actually do it
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Theoretically you could do it, but I wouldn't waste the time. Make sure you verify the length when you're done.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Carquest will stock those joints or have them available next day as well.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    which end is at the dif?
    if it is the female splined part you can do that
    I think it is a much better idea then the conversion joint
  7. mechted
    Oct 19, 2003
    765
    Granbury, TX
    ok well i went looking tonight and the whole second shaft would have to be moved over.... the slip splines are at the center bearing, changing shafts would probably require a rebalance, so, yeah... wont work so well
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Next time you have some money to spare , whether its broke or not, buy a spare and keep it in truck /forums/images/graemlins/thumb.gif
  9. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I agree with paul. I usually try to have a spare anything that would be a pita to be without for more than an hour. tre's joints, belts, hoses ect. I have a spare of every joint in my truck for just that reason. And it is a bonus cause the next time you need to replace it you have it and if you are broke no problem it is already paid for.
  10. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I agree with both of them. They try to carry spare parts that would be a PITA to get, I try and carry spare everything. /forums/images/graemlins/rotfl.gif You name it there is a good chance I will have it with me. That is why guys who run light on the trail spare like Matt like to wheel with guys like me. I probably have enough stuff for both of us. Call it paranoia (sp) I call it prepared.
    I carry the spare conversion ujoint to adapt a 14bff to a 1/2 ton shaft already installed in a spare shaft. I carry all the parts I can carry. It would need to be a major failure (motor, trans, tcase) for me not to have the parts to at least limp home. Like mentioned, buy the parts when you can afford them. I bought my collection of crap over the last few years. A little here, a little there all adds up.
    Harley
